sin_cal_hd
Jun 12, 2014Explorer
Y-Guy wrote:
1) Yes you need the bars even with the bags. Your hitch probably states that as well, certain weight up to # without WD and above that you need WD. Deflate the air bags unhooked, use a measuring tape to measure the top of front bumper and rear bumper to ground. Now hook up, use WD bars and measure again, adjust air bags so you're level and should be the same measurments as without the trailer or equal for front/rear bumper.
i put about 35-40 psi in my bags. Trailer sits level. No WD bars driving around block. No faster than 25mph.
So I should hook up. Measures front and rear bumpers. Then tighten bars to level. Add air in bags?
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
