cummins2014
Dec 22, 2015Explorer
Kevin O. wrote:
I know I'm not the sharpest tool in the shed so I am hoping some of you can help me. I want to install the Reese bed rails(#RP50082-58) in my truck myself. I want this kit because it looks much stronger then the universal kit. The problem is every video I find on youtube and even the instructions from the kit shows the use of a hitch to find the placement for the front rail with no mention of any measurements?? I'm going to be buying the Pullrite 2700 Superglide hitch that adjusts to any set of bed rails.
So the big question is, how can I find out the measurements for the front rail so I can install these without using a hitch??
Kevin
Same kit I installed in my previous truck 99 Superduty same truck. , The custom brackets will position the bed rails, and there is instructions that come with the bedrails that give the measurements.
Pretty simple install, done a couple fords with this same setup, no problems. Have you bought the kit yet, all the instructions should be with it .
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
