cummins2014
Dec 23, 2015Explorer
Coach-man wrote:
had that same hitch on my last truck. Those holes are not there to adjust for the spacing of the rails. They are there to allow you to move the entire hitch forward or back from the centerline of the axle. The rails are designed to be spaced the same distance apart for every hitch. That way you can interchange hitches using the same rails. If you purchase model specific brackets for your install they will set the rails at a specific spacing, but there is a slight amount of tolerance that will aloow them to move slightly. You will need the hitch to get the exact spacing. I hope you are shopping online for that Super Glide. I found mine online for 1/2 of what a local dealer wanted.
B.O.
X2, BUT industry standard, means "industry standard" You do not need the hitch, if you install the rails per industry standard dimensions! That way any industry standard hitch should work. Read my post, no hitch, installed per instructions for "industry standard" hitches, and guess what it worked!!!
The dimension you gave the OP to the first rail from the end of the bed is INCORRECT, PLEASE SET HIM STRAIGHT , that DIMENSION for the REESE 50082 custom brackets on a 2001 Ford Superduty is 32*1/4 NOT THE 26*1/2 you gave him . He is going to have a lot of unwanted holes in his bed if he goes with 26*1/2"
You are both right on the Industry Standard, WHICH IS 22" SPACING, and yes the custom bracket dictate where they are located in the bed.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
