maxmorrow's avatar
maxmorrow
Plastic disc on fifth wheel hitch
I bought the plastic disc for my fifth wheel hitch and thought it would help on the mess of grease. It worked fine and when I tried to hookup the other day the jaws would not close completely. I took off the disc and it worked perfect. Just wanted to let anyone that has same problem of what it could be.
  • FlatBroke wrote:
    I don't see where Hensly or B&W are selling the plates.
    Give them a call, I have purchased the 1/8" disks twice from them.
  • Reese part# 83004 is also 1/8" thick. You can get those for $20.95 on etrailer.com Possibly cheaper if you have time to shop around.
  • I have a Pro Series 16k hitch. mine specifies lube plate no thicker than 3/16". I had the same problem you describe. I have yet to coem across one that thin.
    Mine would
    A. Not allow the jaws to lock.
    B. Pinch and smash, or completely break the plate.
    I'm at using grease now. In the hunt for a thin plate for next this season.
  • You can purchase a 1/8" thick lube plate from several places that have been mentioned in this thread that may work for you.
  • For the usual reasons I bought a Hensley TrailerSaver TS3 hitch. Having read other forums I ordered a 1/8" plate at the same time. When I hooked up the upper ridge of the kingpin groove was riding on my hitch jaws rather than distributing the pressure to the plates. I had to stack the 1/8" plate with a 1/4" plate so that my hitch jaws were centered in the kingpin groove. Hook up is now easier with a creamy ride. Been using this combo for 3k miles with no problem.
  • Thanks fellows for the good info. I purchased a new truck and a B&W hitch this fall. I was really concerned about the thick jaws as I have been known to ruin Teflon plates while hitching. My current plate has been around for some time so I have not had any trouble hitching. It is good to learn that thin ones are available.
