cruz-in wrote:
Hi Team,
Made the decision to go LT....after tons of research I decided on Bridgestone Duravis R250. So now the tire size question...
I have a 28 foot 5th wheel with dual 4400 pound axles (trailer GAWR rating is 8800 pounds. Unloaded weight is about 7500 pounds and max loaded is about 10K pounds. Pin weight unloaded is 1350, I suspect about 1800 laoded. Trailer usually comes with 15 inch wheels, this one has the optional 16 inch rims. Currently has 235/80/R16.
Looking at replacing with Bridgestone Duravis R250 225/75/R16. Load Range Index 116 (2496 Pounds).
My questions:
1) Do you think I am good to go with this load range/size? Seems to me they should work just fine given the weights I am working with.
2) Wally World now has them for $214 a piece with free shipping to store (pretty great price). Will not be using the trailer for the next 5 months. Should I wait till spring or go for the good price that Wally World has on them? Will being installed and sitting for 5 months affect life of tires?
Thanks
That would be a good choice. But you need to verify that the weights listed are accurate. Some trailer manufacturers don't do a good job in this area. I'd recommend getting the trailer weighed BEFORE you buy tires.
Weighing the trailer? Fully loaded with everything you've ever put in there, including full water tanks.
Tire by tire, please. If not, you need to account for side to side and front to rear variation. I recommend using a 10% value for axle by axle measurements, and 15% if all 4 are weighed as a unit.
