partsman01's avatar
partsman01
Plugging fifth wheel into bumper plug?
So on this 2003 GMC 2500HD that I bought recently I was finally installing the fifth wheel hitch and the brake controller, then I cut the tie straps from the wire harness between cab and box to hook up the fifth wheel plug, but before I did it, I noticed the plug at the back bumper hitch is the same, so installed the fuse into the fuse box under hood, then plugged in brake controller and I had power, then tried pushing the brake pedal and you could hear brakes humming on fifth wheel. S
o I am wondering if that is the plug I should use, I don't figure I will add the one at the front if this one is already set up and appears to take the load, anyone see any problems with using the factory hook up at the back receiver hitch?
I am thinking the wires should be all the same.
Any input?
Thanks
  • The 2011 2500 hd had the wire harness for the bed already there along with bumper plug.....all dealer had to do is mount plug in bed and hook to existing wires....maybe your 2500 hd is prewired too for a bed hitch.....
  • I plugged into the bumper plug for 5+ years when I had a 5er, no worries. Now have TT.
  • I think the only disadvantage is that the 5ver cable has to hang over the tailgate. I kind of have a problem with that.
  • The factory 7-pin at the bumper will certainly work. Most folks mount the second 7-pin in the bed for aesthetic reasons, not wanting to drape the cable over the tailgate of the truck. I added the second 7-pin in both my current truck and my previous one.
