DazedNConfused
Apr 21, 2014Explorer
Plumbing question -- joining 3 primary lines together
QUICK VERSION: What does the manufacturer use to join the city water and water pump to the main supply for the RV?
LONG VERSION: When I purchased my new RV last year, I shipped a dual-cartridge water filter setup from Hydropuretechnologies to the dealer for them to install for me prior to taking delivery. This weekend when I un-winterized the fiver, I pressurized the system with water and found a little standing water in my basement area. I removed the storage walls and traced the problem back to the inlet neck on the aforementioned water filter. From the look of things, the dealer hacked this together...and it wasn't done properly. I confirmed this when I spoke with Hydropuretechnologies support. Moving forward, I going to locate the filters outside when we camp since they are a serviceable item (media needs to be changed once a year) and I don't want to remove the storage walls to get access to them even though I'd only be doing this once a year. I got the information from the manufacturer on which connections to use to do this properly and will source them locally.
However, now I have three lines in the RV plumping I need to join together. The city water and water pump were both going to the water filters. The output of the filter went to the main RV plumbing. Because I want to use the camper this weekend, I joined the city water and main line together and I capped off the water pump as a temporary solution I usually carry about a 1/4 tank of fresh water on-board for washing hands and stuff when we aren't hooked up to a city line so I want to put the water pump back in service as soon as I can.
When I went to a few home improvement stores, I couldn't find a 1/2" tee to bring those three lines together. I found some brass ones online, but they are only for non-potable use. Because this is the first I've seen this plumbing, I don't know how this was all joined together from the factory....so I was hoping someone on here could enlighten me...and if it's the tee that brings the three lines together, where I can find one safe for potable use?
Hopefully I explained this well enough so you understand what I'm asking.
Thanks.
DNC
Thanks.
DNC
