cdlaine
Nov 13, 2017Explorer
Pocket door help....
What you are looking at is the top rail for the pocket door on my 5th wheel. The door separates the bedroom from the main living area. (door is removed in photo). Look closely and you will see the most distal screw has worked loose thus blocking the door from opening all the way. (also , the very next proximal screw is awol). So , my query, ... the distal screw (Phillips) is farther back than the length of my arm, and, my beefy Python will not fit in the space allotted (one would have to
be anorexic).
How do I tighten/replace these screws ??? (there is no lateral access).
What tool /extension combo is needed ?
Thank you,
Charles
Pocket door rail....
be anorexic).
Thank you,
Charles
