dsnuggles's avatar
dsnuggles
Pocket door
So I have a 2017 Fuzion 369 and the master bedroom door is a pocket one. I wanna put a lock on it, but I can't seem to find one yet. Have anyone on here put a lock on their door and what kind?
  • My Arctic Fox pocket door on the bathroom used one like this one around $10:
    Even simpler is this for under $5:
    Here is what I used, search:
    Kwikset 335 Round Bed/Bath Pocket Door Lock in Satin Nickel
    Cost around $19.00, Home depot or Amazon
    Install is pretty simple, works great to keep privacy and unintended walkins.
    Good Luck.
    Gear
    Ours has a lock on it, never used it then one day the DW closed it and it locked, broke the lock actually and she was stuck in the bedroom. Had to pry it open. Fortunately didn't hurt the lock/pull cosmetically but the lock is toast now, I need to pull it off and gut the lock mechanism for now it's held up/out with electrical tape.
  • Locking the kids out - good times in the desert :)
  • joebedford wrote:
    Depends on whether you're trying to lock somebody out or in.
    Both.
  • Depends on whether you're trying to lock somebody out or in.
  • Various degrees of fancy, a bolt type lock either into floor or door frame. You want to lock in position when traveling, otherwise it may come off of track, same type of lock can be used for privacy.
