cdlaine's avatar
cdlaine
Pocket door help....
What you are looking at is the top rail for the pocket door on my 5th wheel. The door separates the bedroom from the main living area. (door is removed in photo). Look closely and you will see the most distal screw has worked loose thus blocking the door from opening all the way. (also , the very next proximal screw is awol). So , my query, ... the distal screw (Phillips) is farther back than the length of my arm, and, my beefy Python will not fit in the space allotted (one would have to
be anorexic).
How do I tighten/replace these screws ??? (there is no lateral access).
What tool /extension combo is needed ?
Thank you,
Charles
Pocket door rail....
  • Something like this may be?
    https://www.amazon.com/OriGlam-Extension-Adapter-Magnetic-Screwdriver/dp/B06XKW4VZ2/ref=sr_1_4?ie=UTF8&qid=1510603501&sr=8-4&keywords=angle+socket&dpID=51MNNV41jTL&preST=_SY300_QL70_&dpSrc=srch
  • Thank you all very much.
    DownTheRoad and Mandalay Parr.... your ideas will be Plan A.
    Newman FullTimer... Plan B. (but probably should be Plan A for
    the next time this happens).
    Ol' Bombero.... here is a photo of the on door mounting device and
    securing plastic lock. The only "stops" I'm aware of are the back
    end of the pocket door slot, and a securing snap-on strap on the door.
    I called the Mfr. and learned how to remove the door... they have special
    extension devices to assist installation. The "awol" screw remains
    unaccounted for... I hope it was originally installed. Thanks.
    Pocket door mount hardware...
    Thanks again ...I'm out camping in the desert so the solution will
    have to wait until back at the sticks and brick. I will leave the door
    off hoping to avoid damage en route.
    Charles
  • Get one of those palm size power drivers and duct tape it to a stick. Practice reaching in with it. Then tape it on or create a remote trigger and then engage the screw. Chris
  • drill a 2 inch hole in the cabinet at the back and use a 90 screwdriver rhen put a hole plug in the hole like for a sink.hole filler
  • Interesting "combination" on the closest screw in the photo.
    Is that intended to be a stop for the door to keep it from coming
    out of the track.....and maybe the rear one also?
    (but that one appears *not* to have a stop/spacer nut)
    Do you think the "awol" screws were ever there?
    Easy (?) solution - call mfgrs Tech Line, ask them.
    :h
  • Whats on either side of those panels. I would just try to take off the panel to get at it
