Rygar's avatar
Rygar
PO'd Rv owner
Right now, I'm sitting here totally pissed off with Rv manufacturers. Last year while driving from the west coast to Toronto and back I had 2 major tire blowouts. This year, I'm planning on a longer trip. East. south, west and then north. So, I decided I needed 4 new tires for my Fifth wheel. I start my research online and talking with tire stores. I also check the forums here. I was a noob before I started this search. No longer. My Montana fifth wheel That max weight is 16,000lbs was delivered with Goodyear Marathon tires rated at 3000lbs. x 4 = 12,000lbs. So, this trailer was destined to fail. The blowouts were inevitable. Do these manufacturers not care one iota about the lives of the people who give them their money. I don't know how they can get away with this. I've only found two tires that would work on my trailer, both 14ply. Sailun and Samson. Sorry, rant over.
  • Figuring 20 percent pin weight, each of your tires is carrying 3200 pounds.
    I also just put on the Sailun 235/80-16 tires for my 14k fiver. Each of them is rated at 4080 pounds at 110 psi. In your situation, I would suggest going with the 235/85-16 Sailuns if you have the clearance - they are .9 inch taller. They are rated at 4400 pounds each.
    The 85 series tires cost only a little more then the 80 series.
    * And I agree 100 percent with your rant.
  • They don't give you much safety margin. Put the Sailun S637 G rated 235/80-16s on mine last week. Makes me feel a lot better with extra reserve capacity. They are a lot heavier and more substantial than the GY Marathon that blew out.
