Chakara wrote:
... I'll order the thing and try it a about 6' off the ground level...
-Chak
One thing to consider about mounting it permanently on one spot on your camper, if you park under trees, or in a wooded area, you're pretty much restricted. If you find a way to keep it mobile and consider different options about mounting it permanent, or using a non-permanent mount, if you park anywhere with a "low overhead" you can put the pole in a different location. (just something to think about).... good luck! happy camping!
