joro2548's avatar
joro2548
poor cable reception
I have a 2014 Arctic Fox pickup camper and when hooked up to cable tv at any campground, the reception is all snowy. The hookup box on the outside of the camper says " satellite hookup". Is it possible that this hookup will not work for campground cable and only portable satellite hookup?
Thanks,
  • Turn off your built in antenna booster power switch.
  • But then, why would you expect a connection that says "Satellite" to work with cable?? Might look for the inside end of the cable, If you don't have a satellite receiver, it may not be connected to anything.
  • connect your tv directly to the park cable connection. Ir that works, then the problem is in your wiring or connections. Anything is possible.
