The_Painting_Te
Dec 31, 2014Explorer
Porpoising (Bucking) Fifth Wheel
Discovered quick, simple cure for porpoising, which reduces it to a minimum when you're using cruise control. Ride with your finger on the cruise control "cancel" and press it just as you hit the expansion joint on bridges; coast across and then re-engage as you finish crossing the expansion joint. The bucking is virtually eliminated. This may be old info, but I recently discovered it. Camp on!
