TakingThe5th
Sep 27, 2015Explorer
mtofell1 wrote:
Aside from PSI look at CFM (cubic feet/minute). A high PSI w/low CFM will leave you standing for an hour waiting to pump up a tire. I haul a Craftsman with me that probably weighs 20 lbs. or so. It only runs off of AC so you must also have a generator. The small black lunchbox size DC compressors are handy but you'll be at least a year older by the time your tire is inflated.
Viair 400 specs
12 VOLT - 150 PSI Max Working Pressure, engine must be running during use.
2.54CFM Free Flow @ 0 PSI. This unit has a built in pressure switch which keeps the air line inflated at 150PSI.
Powered direct to the car battery with alligator clamps, comes with a 40 amp in-line fuse.
Great for inflating tires up to 35inches on off-road and agricultural vehicles.
I feel that I generally get at least 1-2 CFM at working pressures.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
