ol_Bombero-JC
Sep 28, 2015Explorer
S-n-L wrote:
To be clear, I will never use this compressor to fill a flat RV tire, only to top them off with 5 to 10 psi.
Method:
I purged one tire to 117 psi and clocked the time to fill this tire to 122 psi.
I hope this information is helpful to some and look forward to hearing your input and opinions on this subject.
Extensive tests!..:C
However, since you were into testing - *why not* deflate your spare (or other tire), as if you had a flat, and see what kind of results you can achieve? - (Never say "never" - as you stated).
Also - for folks with MHs (with an on-board gen) - how about the
above tests (time) with a 110V compressor? ("purged" & flat)..:@
Lots of options for capable 110V compressors from various sources - including Harbor Freight.
Besides the "on-the-road" uses, very handy at home...;)
BTW - before I discovered the benefits of a C02 system - for topping-off or full flats, I have (in the past) carried a 110V pancake style compressor/s (135-150psi capable) - which (IMO) were far superior to the 12V variety.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
