Cummins12V98
Sep 29, 2018Explorer III
wvcampers wrote:
I went from Reese to Andersen rail version. I recently traded trucks and the new one came with the B&W companion mounted with factory puck system. I have towed with it 2 times. I really like the Andersen due to the fact that there is no way to drop the trailer on the truck like you can with a traditional hitch. For beginners the Andersen is a much easier hitch to safely use and very easy to remove from the truck.
Using a B&W you know there is no way to drop the hitch if you simply make sure the hitch and pin box plates are touching each other, the hitch handle is closed and pinned/locked and a quick look to see that the 1" machined jaws are around the kingpin.
Do the above and there is ZERO reason to do a pull test.
About Fifth Wheel Group
