Me_Again
Sep 29, 2018Explorer III
I never did pull test with my Hijacker sliding bar hitch and the same with my B&W, the design of the jaws and dual point cam that the handle is attached to is better much fool proof. As the jaws close around the king pin, the spring loaded handle turns so the cam points prevent the jams from opening. Pin the handle in the closed position and one is good to go.
Larry, I hope you are doing your pull test with the landing gear still down almost to the ground.
Chris
Chris
About Fifth Wheel Group
