- JEBarExplorerto reach the converter in our '06 Titan 34BWKS you open the outside compartment door above the battery compartment .... the converter is located inside that compartment
Jim - C_SchomerExplorerMy 30xxx SB has a center entrance and the 120v and 12V boxes are at the top of the steps, towards the front, behind the louvers. My converter is on the front side of the vertical board that the 120v breaker and 12v fuse boxes are mounted on. There is an outside access door, ahead of the entrance, just for the converter and some auto reset 12v breakers. Flash, I just remembered... There's a thin luan partition to protect the converter so it's a little hard to see behind it. I remove two screws in that partition to expose the converter. Hopefully you just have a blown fuse in the converter... If there Is one. Craig
- RoyBExplorer IIGive us the model number of the panel where the 120VAC circuit breakers and 12VDC fuses are located. The POWER CONVERTER module is usually in the bottom compartment of that unit.
Roy Ken - mpfiremanExplorerThough we have an older unit, ours is located in the bathroom, lower cabinet.
- 1492ModeratorMoved from Forum Technical Support
- midnightsadieExplorer IIlook in the kitchen are or around the floor there should be a vent ,its behind that.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
