- nickthehunterNomad III
You can test the converter to see if it’s working by disconnecting the all the leads at the battery; then, while being connected to shore power, check the output on the 12V side of the converter. If no 12V output you should check the 120V input side of the converter.
No power in means there will be no power out. If you have power in but not out, you likely have a bad converter. If you have power in and out at the converter, you have problem(s) elsewhere. - BeaverCamperExplorer
OK I found it right below the fuse box. So how do I tell if it is working, also is there a fuse for it?
I ask because when plugged into shore power my coach batteries are fully charged during the day with the solar panels and are full when we go to bed at night, however by morning it takes about 4-5 hours of solar charging to get them back up to full charge. Also I dont see the fan on the converter turning at all.
- pianotunaNomad III
Most often there is a circuit breaker for the "converter".
