TLYLE1115's avatar
TLYLE1115
POWER CONVERTER LOCATION
I RECENTLY PURCHASED A 2004 FLEETWOOD WILDERNESS ADVANTAGE FIFTH WHEEL CAMPER AND HAVE NOT BEEN ABLE TO LOCATE THE CONVERTER HAVE SEARCHED EVERY CABINET AND POSSIBLE OPENING I CAN FIND. PAPERWORK WITH SPEC'S FOR CONVERTER WERE IN WITH OTHER MANUALS BUT DOES NOT GIVE LOCATION. ANY HELP GREATLY APPRECIATED.
  • Hi
    I can tell you exactly where it is:
    Go into the basement luggage space on the passenger side - you will see if you look left a tan plastic vent. Undo the screws on the fabric panel to the left of that and you will find it, well hidden, behind there.
  • Mine in my 2004 fleetwood wildnerness lite fifth wheel is behind the electrical panel that sits between bathroom and bedroom, to access the back of it I have to undo a panel in my bedroom I believe, or I think at the bottom of the closet there I can get to the top of it also.
  • Fleetwood has a pretty good support group you can call. It's usually near the batteries.
    Also all caps is considered shouting and rude.
  • Did you look at the back of the electrical panel. That vintage would have it built into the AC/DC panel. Chris
  • Can you find your fuse/breaker panel? it's all in one, including your converter
