Trackrig
May 22, 2017Explorer II
D.E.Bishop wrote:High5er wrote:
I carry all adapters at all times like most of us. 125 is fine for normal use of lights, inverter, awnings, fans tv, radio and even overnight to get your fridge good and cold. Just don't use big power suckers like AC, microwave, toaster, coffee maker etc.. Also high gauge extension cords and a shorter length to the power source is good as well. I use my home power to get her all ready for the big trip with no issues. Enjoy your new RV!! :B
Not to be contrary but why shouldn't I use 120vac to power my on board appliances? Did you mean not to power them with a 15 amp adapter?
With a 30 amp service I can run both AC and MW at the same time.
High5er said to not run the high wattage/amperage appliances on a 15A outlet. The toaster, microwave and coffee maker might work if they're low wattage and the (high) wattage battery charger or something else doesn't kick in at the same time. You aren't going to run a very high amperage A/C on a 15 amp outlet - that's why you have a 30A RV. You don't have 30A service when plugged into a 15A outlet.
Bill
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
