Planning
Feb 07, 2018Explorer
Rock auto (for the Buick Century selection) displays a range of quality: economy, daily driver, premium, heavy duty.
Their "premium" distinction went to the Raybestos EHT215.
Raybestos says this: Gain a new level of control and confidence with Element3™ brake pads with Enhanced Hybrid Technology (EHT)™). The world’s first brake pad to deliver the best attributes of ceramic and semi-metallic all in one pad. Element3 supports optimal performance, improves pad wear and durability, and increases stopping power during aggressive braking.
Features:
One million miles of testing: Including Dyno Validation Tests, Independent Real World Tests & Tested for Unsurpassed Performance Across a Range of Problematic Tendencies.
Quiet Steel® Shim: Noise reducing shims use a damping system construction to promote quiet stopping for added performance in a wide variety of temperature ranges and vehicle platforms.
Brake Hardware Included: Abutment Clips, Piston Clips, Spreader Springs, Anti-Rattle Clips, Mechanical Wear Sensors (where applicable)
Friction Material Hybrid
Pad Thickness, Inner Overall (IN) 0.190
Pad Thickness, Outer Overall (IN) 0.130
Plate Length, Inner (IN) 4.920
Plate Length, Outer (IN) 4.920
Features:
About Fifth Wheel Group
