Are you talking about the tires on your RV still showing tires when you pull out in your truck? If so all you have to do is hold the mode & minus buttons at the same time and it will put the RV to sleep, meaning it will no longer show on the screen. When you need the 5th wheel again hold the same 2 buttons and it will again show on the screen.
If you are not talking about that, have you tried taking off the antenna like you did with your PP? Possibly just turning off the monitor then back on once you leave the the area should take care of the problem.
As far as maintaining signals, with a truck, 5th wheel & utility trailer, you may need a repeater because of the distance and possible interference from front to rear.
We did not need a repeater with our 96 Dodge pulling our 38'Carriage but when we bought a 2014 Dodge pulling the same Carriage, we needed to add the receiver because of all the interference in the new dash.
Hugs, Di
RCMAN46 wrote:
I have read many postings about TPMS systems.
I first purchased a Pressure Pro system about 7 years ago. Last summer after years of trouble free operation and the system saving damage from tires picking up nails, bolts and a tire stem failure the batteries in my sensors reached their end of life.
I had read many good reports on the TST system. The flow through sensors caught my eye as it should allow pressure adjustments without removing the sensor. (On one occasion I did have a sensor leak from not installing it tight enough after a pressure adjustment.)
I decided to try the TST flow through system. After installing the sensors on my truck I saw how far beyond the wheel they protruded. I was concerned when I go off road and got into deep mud or snow the sensors would be damaged.
I called TST and told them my problem. They agreed to replace the sensors at no charge except postage. I agreed as the issue was in no way the fault of TST.
Shortly after I had the system installed I noticed when I would leave a campground I was still getting what appeared to be valid tire pressures after 30 minutes or so. But when we had finished eating our supper I did have loss of signal alarms on the sensors that were on my trailer.
I did some testing and found that it takes almost exactly one hour before the TST system will set a loss of signal alarm.
Again I called TST and they indicated this was perfectly normal for their system.
I still had a couple sensors from my Pressure Pro that still had some battery life. I installed one on a tire I had in my shop. Then I drove the truck out of the shop closed the shop door and removed the antenna on the receiver. I got a loss of signal alarm in 15 minutes.
I tow a 5th wheel with a utility trailer behind the 5th wheel. With the 1.5 inch antenna that comes with the TST I was not able to maintain communication with the Utility trailer. (The Pressure Pro has a 3 inch antenna)
So I have two issues with the TST vs Pressure Pro. It takes 4 times as long to notify the loss of communication with a sensor. The TST uses a shorter antenna than the Pressure Pro thus probably has less range.
I would be interested if anyone else has noted the long time for a loss of signal alarm on a TST system.
A very easy way to check is have the system operating then with the TST system remove the receiver after you have put it in battery mode. Take the receiver into the house and remove the antenna. Then monitor the display and note when the receiver sets the loss of communication on each tire. (note this may take one hour)
