Halmfamily wrote:
edatlanta wrote:
Puddle Pirates wrote:
I've used a power washer on a low setting for years and never damaged my rubber roof. Twice a year cleanings. Use the washer get get off the grime then a rubber roof cleaner and bristle brush. Finally a coat of uv protectant.
I won't have to worry about pressure washing now, as I had a new RV Flex Armor installed last month after some tree damage to the roof. Washer is never going to damage that roof.
I just had RV Flex Armor applied to my roof after my 5 year old EPDM roof membrane started leaking through the material. Yes it was kept clean and maintained per manufacturer's recommendations. My solution to any rubber roof issue is RV Flex Armor. I would do it immediately after purchase of a new RV. I won't EVER mess with rubber roofs and caulking them again EVER!
What is the cost of the RV Flex Armor?
I was told each of their authorized application locations may be different, but mine was done in Madison, MS and they charge $170.00/linear foot. Not cheap, but no more roof issues and it is a LOT quieter inside now also.
