RCMAN46 wrote:
cruz-in wrote:
RCMAN46 wrote:
I recently went with the TST system. If I were to be able to do it over I would go back to the Pressure Pro which served me well for over 5 years.
I changed to save a couple dollars.
Why would you go back to PP? Was there something you did not like about the TST system?
The pressure Pro system has more range from sensor to receiver. At least on my setup it seams to have more range.
If the receiver does not get a signal from a sensor the STS system will not notify you of the lost signal until it has not received a signal continuously for about 1 hour. The Pressure Pro will notify in about 15 minutes.
So if the TST were only able to get one update each hour you would not know there was a problem. That is most of the time there is no data communication thus a tire could go flat and you may not know it. Whereas the Pressure Pro would be one each 15 minutes. I would prefer both would give notice if there was lets say 3 or 4 continuous update failures.
Maybe someone will market a better system someday.
As for customer service I found it very good for both companys and would rate them the same.
Distance isn't an issue for my TST 507 with a long bed dually and a 40' triple axle toyhauler. I have not needed a repeater and I get consistent readings.
It updates quickly so I don't believe you're correct with thinking it only updates once an hour or so. I've seen the tires change temperatures from one cycle to another, which happens as it goes through the different tire positions.
I think you're mistaken about the TST system needing an hour to tell you if a tire sensor drops out. I don't know where you came up with that since there is no way of knowing the sensor has dropped out until it beeps. So how would you know it was hour before it missed the sensor?
I'm very happy so far with my TST system. I only have one thing I would change: I would give the flow-through sensors a pass. They take way too long to allow a decent amount of pressure change.
