Bedlam
Sep 23, 2013Moderator
I looked at them also but was only focused on the ones with an aluminum chassis. Feather Lite is another brand and they can be much more upscale with fireplaces, slides and accent lighting.
The other option is car haulers with LQ's. InTech and Millennium Trailers make aluminum chassis haulers with LQ. Millennium is less expensive and uses common RV fittings you would find the big manufacturers while InTech will do custom or off the shelf.
All of these above could put in 100+ gallon fresh tanks and 40+ gallon fuel tanks with good sized generators. What I liked the best was the fact you could choose your overall length and LQ length leaving you with the size garage you needed. The aluminum chassis GN models in a 38' length with slide, AC and generator were about 9000 lbs dry and could be configured with 7000 lb axles in a dual or triple setup. I wanted at least 18' of garage and could not find many conventional TH choices - Those I did find were too heavy for my TV.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
