time2roll
Jun 22, 2014Nomad
Smoke90 wrote:
The converter is a progressive dynamics inteli power PD9280
13.6 V 80A
Excellent converter. No upgrade needed. Should charge at 14.4 volts for a full four hours when the battery is low. Verify with your voltmeter. There is a pendent available to manually change modes if needed.
Solar kit looks fine. I would tend to add a second 100w panel from the get go.
You can buy brackets or make your own from angled aluminum stock from Home Depot/Ace. Yes they will hold up in all normal wind conditions.
Forum Members Solar Installations With Pics
If the battery was allowed to run down in storage it may have lost some capacity. Solar may help bounce them back... if not you will need to consider replacement.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
