Crazy_Cooter
Jun 23, 2014Explorer
You can't power a battery charger with an inverter from the same battery bank and expect to get ahead.....That is impossible! You would end up 30% in the hole minus whatever the truck will trickle back there.
More available battery power, reduced consumption, or supplemental charging are the only solutions. I'm a big fan of solar if the sun shines in your area.
It is quite possible like wwest suggested above that one cell is bringing the whole bank down too, but regardless.....You need more storage than 120Ah to power a decent RV with minimal generator run time.
100W solar is enough for storage, but 200w+ would be better for boondocking.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
