steiny93
Jun 16, 2014Explorer
so when you flip the disconnect (which removes the battery from the mix and places the entire 12 volt load on the converter) it pops the 2 30amp 12 volt fuses in the converter. (is that correct?)
do you have a ton of 12 volt appliances on when you try this or everything off? If the battery isn't connected at all to the system does it still pop the fuses? Or is the failure tied to the disconnect switch?
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
