Diesel_Camper's avatar
Dec 04, 2015
Propane Qucik Connect Question
I just purchased a Mr. Heater Big Buddy for our 5er and it has a low pressure input which can be fed from the low pressure side of the propane system. I was thinking about Tee'ing off of either the existing furnace line or the hot water heater line with flare fittings and adding a quick connect inside the 5er for this heater. My concern is leakage. I have seen my share of air fittings that leak, not sure if the propane ones are built better and safer?
If not, then a 1/4 turn valve before the quick connect might do the trick?
