No sir, this is not the way to do it. The lever should be pointing to a full tank. Then when that one runs empty the switch over to the OTHER tank will be automatic. Turn the lever toward that OTHER one when you see the indicator showing empty, fill that empty tank right away and leave the lever pointing as you last set it. Then this cycle will repeat. It works.
