BFL13
Oct 24, 2017Explorer II
Propane Woes Question
Another question about the propane from the big sideways tank in a Class C.
After we bought this rig recently, turned on the propane tank gas valve, and had a heck of a time getting the appliances going. Eventually, I did get them going, so I thought we were in the clear.
Shut off the big tank and drove up to the scales and around a bit and back and parked back at home. A few days later, today, turned the big propane tank on again and all that would work is the stove top burners. After a while, I got the fridge to work on LP. Swearing helped I am sure! But still no hope with the previously working ok water heater and furnace.
After some more time and swearing the water heater decided to work ok.
I finally got the furnace to work. The fan blower part was going great from the get-go but no heat. This went on for a few hours while I monkeyed with the thermostat and so forth (more swearing, but to no avail)
I then pulled a wire off a black switch over to the left, which stopped the blower and then re-attached the wire. Blower came right back on, and after a bit there was a click and a smell of gas. But no ignition. Did that some more times and eventually it fired up. Hooray!
But then it seemed to stumble a few times (I am suspecting air in the line of course) and eventually ran well and true.
So now all the appliances are happy and everything seems ok. BUT!!!
We don't want to drive to the campsite with the propane on. The big worry now is if this whole agony will repeat itself when we get there and turn the big tank valve back on. Will the appliances work or not? Or will we have to fool around for hours like this time? Yipes!
Is it normal for air to get in the lines between tank shut- offs like that after a few days? If so, can you hope the appliances will fire up ok if you turn the big tank back on after shutting it off ---that same day--- after a drive to somewhere?
What is normal? Thanks.
