marspec
Jun 24, 2013Explorer
Propane Supply to Reefer in Slide
We have a Lifestyle 37RESL and are having problems, among other things, with the Norcold reefer remaining lit when traveling. At first I thought it was the reefer but believe I have located the problem. The reefer is located in the slide and when the slide is retracted the hose is pinched where it exits the interior of the rig enroute to the scissor arm holding the wiring and propane line. I have tested my theory not only by a visual inspection but by turning stove on and retracting the slide. The flame slowly reduces and extinguishes as the slide retracts
The propane hose where it wraps around the scissor is wrapped with a protective wire shield but on my rig the hose exiting the rig interior is not. I believe it should have some protection. For those of you who have a full wall slide, or any make where the reefer, stove, or water heater are located in the slide, does your propane hose have any protection where it exits the interior of the rig?
Thanx,
Chuck
2013 F450 towing 2013 Lifestyle
Thanx,
Chuck
