time2roll
Nov 11, 2019Nomad
The existing automatic regulator should indicate the empty cylinder. There will be a pointer that indicates the primary cylinder. Check that the pointer is actually pointed at one or the other... not in the middle. When you remove and fill the indicated empty, switch the pointer to the opposite cylinder.
Repeat each time you see the red indicator. Check daily during heavy propane use.
About Fifth Wheel Group
