dapperdan
Nov 11, 2019Explorer
Old-Biscuit wrote:
Only one is going to go empty at a time.
When Indicator goes from GREEN to RED.....swap indicator lever to other cylinder
Then remove the empty one and go get it refilled.
TWO 30# cylinders (14 gallons) will last a long time
FTng we went 6 weeks on ONE 30#
Pressure inside cyliders doesn't change a lot until almost empty
Overthinking the issue.
We've been using this method for 10 years now, works GREAT for us! One tank valve open, one closed. When tank "A" is empty switch to tank "B" and when it's convienent, get tank "A" refilled. Old Biscuit is spot on!! 30# tank will last a good long time unless you're running the "h" out of your furnace! :B
Dan
About Fifth Wheel Group
