jadatis wrote:
I am a bit confused now, you write
Tuesday, (1-28-14) I am putting on LTXMS2 Michelin tires all around, ST235/85R16. The load rating is a bit less than the ST tires, but well within spec. The size is slightly taller, but I should be OK. The load rating is 3042 @ 80 psi, with 5200 lbs axles on the trailer. That gives me some breathing room. But I also weighed the rig, the trailer rear axles weighed 8,240 lbs, while the hitch weight was an additional 1,860 lbs.
Are you saying that tuesday you will again put other tires on ST235/85R16 and those are others then the Michelin LTXMS2??
What you have try to determine is the maximum speed for wich the maximum load is calculated for. For that you have to read my topic I linked to in former reaction.
He is have a hard time getting ST out of his brain. I think he intended to write LT235/85R16. Chris
