riltri wrote:
MNRon wrote:
Why would you cancel the 5er package on a new truck? I believe it comes with in-bed 7pin and some other things. I also ordered an F350 within the last month and can’t imagine not getting the 5er package.
Actually found/bought a F250 with 6.75 bed that came into the dealership the previous night but it does not have the puck system. I'm trying to decide on a hitch but I do NOT want rails permanently mounted in the bed. The dealer quoted the Patriot but I did not realize it required the rails when I wrote the check.
It appears that I will need a rail adapter that can be easily removed. Still searching!!
Its not a bad way to go if you have the puck system, the adapter. But direct fit to the pucks is the more simple way , it eliminates the additional cost of the adapter ,and removal when not needed.
At the time I bought my present truck with the fifth prep ,there were not a lot of choices on hitches that fit the pucks, plus I wanted to stay with my existing manual sliding hitch, so I went the adapter . Although I can remove the adapter I very seldom do. I have since went to the steel Andersen that also fits on the adapter .
