tinner12002 wrote:
Old-Biscuit wrote:
2016 RAM 3500 Dually with 3:73 gear---24K
2016 RAM 3500 Dually with 4:30 gear---26K
Sure the other two in 350 Dually are similar
My 15 Ram with 4:10 gearing is rated to pull 29,600.
That is true but you will not find a 5er that has a low enough pin at that weight you can tow. That rating is in reality based on a gooseneck trailer.
My 39TKSB3 weighs 23K and the pin puts me at my RAWR. If I went to a longer DRV with 3 axles I could easily tow a heaver RV since the pin percentage usually goes down with a triple axle RV.
