Bedlam
Jun 10, 2016Moderator
You will most likely be limited to 5000 lbs due to the RV chassis extension on your motor home. 8' wide enclosed trailers will weigh 2000-4000 lbs empty depending on the length you choose. If this is just for art supplies and paintings, you should be fine with weight. If you do stone or metal work, you will have to watch how much you load up the trailer.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 15, 2026
