C_B_
Apr 13, 2019Explorer II
Walaby wrote:+
The tow issue is easily resolved. The capture plate is easily removed.
Having said that, if for whatever reason, you have to use your truck/hitch to tow someone else's 5er, that could be a problem for sure.
Mike
Here's how I resolved the issue using the my Superglide
to tow someone else's 5th wheel
Made a Slide Stop Adapter so I can tow other 5ers that don't have wedge plate.
Front end is notched to fit against Turn table cam arm assembly.
Adapter fits in between slide rails. then is tightened and jam nutted in position to stop slide from working.
Now I can tow any fifth wheel.
Someone else towing my 5th wheel.
Modified wedge plate for quick install and removal.
Drilled holes inside of the wedge of the wedge plate.
drilled matching holes in pin box and welded nuts inside of pin box.
Made a pin set up on front of pin box and wedge plate.
If my 5er needs to be towed by someone else,pull pin, take out 2- bolts, good to go.
C.B.
About Fifth Wheel Group
