Hvyhauler
Sep 29, 2014Explorer
n7bsn wrote:
I expect the pins in question are NOT conventional hitch pins; ie the ones that connect the bed-pins to the hitch.
The bed pins are probably only available from PullRite
Good point... if the op is referring to the large "rail" mounting pins (4 each) which go through the truck bed into the underbody mounts... these will definitely be a Pullrite only part.
Still... call Pullrite and explain what parts you need. They have great customer service & will work with you.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
