Walaby
May 02, 2021Explorer II
Interesting JIMLIN because PullRite recommends WD40.
Page 6 of users manual
When storing the SuperGlide hitch, you should be sure that the Fifth Wheel Plate parts and Way Tubes are lubricated with WD-40 to ****** the formation of rust. Cover the entire assembly to prevent accumulation of dirt, grime, or rust.
To protect against rust and to enhance the ease of turning on the Way Tubes,
a light oil (WD-40 or a 3-in-1 oil) should be applied to the Way Tubes’ top and inward facing sides and between the front and rear openings in the Plastic Wear Plates positioned around the Turntable/Cam Arm Shaft.
The PullRite Superglide is my first, and currently only, 5er hitch, and I love it. It's pretty **** heavy though.
Mike
Mike
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
