C_B_
May 03, 2021Explorer II
Prior to using plastic wear plates Pullrite recommended using white lithium grease for lubrication. Never used grease on on mine. Grease attracts dirt and grit.
Have been using a product Called SlipPlate dry graphite for 18 years
with no problems.
Below is from Pullrite owners Instructions.
November 2009 brings a new innovation from PullRite Towing Systems with the use of plastics.
The Turntable Cam Arm Assembly is now equipped with Plastic Wear Plates. It is imperative that you read each of the
following sections so you can learn how to care for your hitch properly.
The Plastic Wear Plates of the SuperGlide’s Turntable Cam Arm Assembly were designed to glide along the surfaces
without the need for heavy lubrication. To protect against rust and to enhance the ease of turning on the Way Tubes,
a light oil (WD-40 or a 3-in-1 oil) should be applied to the Way Tubes’ top and inward facing sides and between the
front and rear openings in the Plastic Wear Plates positioned around the Turntable/Cam Arm Shaft.
C.B.
with no problems.
C.B.
About Fifth Wheel Group
