MFL
Nov 06, 2015Nomad II
Normal driving going forward, no need to worry. If you are making a tight U-turn, better take a look, depending on FW front. If you are backing, best to have spotter watching. In most tight backing, it is best to pull ahead a little, then back again.
Can I turn my truck 90 degrees to my FW? I doubt it, but would not, even if I could. Can you back a TT to 90 degrees? Nope.
Some standard hitches are adjustable ahead/back, my B&W is. I have my pin about 40"s behind the cab, just ahead of axle center.
Jerry
Jerry
About Fifth Wheel Group
