n7bsn
Nov 20, 2013Explorer
The Superglide is a good hitch, what adapter are you putting on the pin-box? I like the simple bolt on, that way I can remove it when I drop the rig off for service (the weld on, is well.....) Of course with the adapter no, on one could easily steal the rig.
Some points:
*Getting the rig the right height for an easy hitch/un-hitch is critical.
*Don't use a disc between the hitch and pin-box
*Read the manual about hitching/un-hitching
At some point you might find the hitch will simply not un-hitch. If this happens, lower the legs, remove the two pins that connect the hitch head to the body, raise the trailer....at some point the tension on the jaw will be removed, then pull the handle and lower the trailer to put the hitch-head back on the body.
Some points:
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
