Vulcaneer
Nov 20, 2013Explorer
shadoow wrote:ford truck guy wrote:
I like my 18K... when un-hitching it sometimes gives me trouble pulling the handle... What I do is put my wheel chocks under the trailer wheels , place the truck in reverse (to take the tension off the jaw) , put me brake on(truck back in park).. viola - never an issue from that point...Joe
x2
X3...This is the correct answer. Others suggest you raise the elevator legs until you see a gap. That brings on potential problems. If raised too high, the hub on the bottom of the kingpin can upset the steel area around the jaw. And when that happens, you can find that the jaw does not close completely. These hitches are pretty precision. Mushrooming some of the steel, throws off the tolerances and the hitch will hang up.
My recommendation is to back into the hitch to relieve the tension on the jaw. Then the handle will pull easily and the jaws will disengage completely. This is the right way to do it.
And yes... you gave the wife the right answer. There are some things you can cheap out on. The hitch is NOT one of them.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
