BugsRLB's avatar
BugsRLB
Pullrite Superglide or Demco Hijacker?
Back in April we turned to sharp and broke the rear window out of the truck. 2018 Ford F350 Short Bed https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29872183/srt/pa/pging/1/page/1.cfm
Have since sold the Reese hitch and are looking for an auto-slide hitch. Think we have narrowed it down to Pullrite and Demco.
Pullrite seems to have hitch/unhitching issues, needs separate plate on kingpin, can't tow other 5vr's without plate.
Demco seems to have chucking issues.
What are your recommendations or thoughts? :h
  • I'm too new to be a seasoned expert, but I have the Demco and like it. Pretty easy to hitch and unhitch, easy to SEE whether it's hitched correctly. I've put over 20,000 miles on this rig in 3 years and we do get the chucking on bad expansion joints. I'm looking into getting the Air Ride Trailair pin box to help smooth things out.
    JK
  • I use the Superglide and its awesome..... bolt on a capture plate onto the pin box and roll away !
  • The Ford has the new Puck System. Reese hitch was not adjustable.
  • I am wondering how close the Reese hitch (center of pin) was to the back of your cab. Some non-slider hitches can be set back over axle center, allowing just over 40"s between pin center and cab. You also have the Andersen option, with a coupler that can be reversed, allowing more clearance. The Pullrite is popular, but heavy, and alignment issues, like you mentioned.
    Are you using rails or pucks?
    Jerry
