homeschoolin
Dec 12, 2020Explorer
time2roll wrote:
After the initial coat, just a light touch up the first couple trips. You can tell by the sheen of the metal when more is needed. Wipe it down with a clean cloth to better tell. The graphite goes on like paint and like any paint you can tell when it needs a touch up. Graphite bonds to the metal so less is needed over time.
Been running a Superglide with slip plate for over 10 years. Other brands are fine too.
Good. Thanks. I did not realize the Superglide called for the graphite dry lube also. Is the dry lube for the slide rails? Doesn't the slip plate take care of the hitching area?
About Fifth Wheel Group
