dsrace
Dec 08, 2022Explorer II
Deltabravo, I have seen that video,that was a bad day for sure. I most definitely hope that doesn't happen and don't believe it will. Those failures are mostly found in the ultralight series or anything that has the word lite in its name. The frames/axles are a large portion of the uvw of travel trailers. Ultra lite units use weaker frames to shave weight. Pretty much anything that is labeled 1/2 ton towable imo. The frame under this dune sport toyhauler is a lipped frame. Either dune sport specs them with double the out riggers or they add them. I know they do make some modes at there facility to the frames to improve them. When I say double the out riggers, I am comparing this frame to all the other toyhaulers I he owned or looked underneath. I don't know them all either. The tongue on this unit is thick wall steel tube. Haven't put the dial caliper on it to measure it. The frame itself doesn't look bad and the actual skeletal structure of the toyhauler body appears to be well built. The roof was finished poorly, there inspectors either need seeing eye dogs or they need access to the cad prints and invoices the customers signed off on.
About Fifth Wheel Group
